Bed light factory hole plugs
RHeller1
So my truck for some reason or another does not have covers where the factory bed lights are suppose to be installed. I am guessing they were removed when the bed got rhino lined and never replaced. whatever...I am trying to find a part number or a set of these? Cant seem to find the part number on any diagram. any help?
Pretty sure it is 68312765AC
Had line x sprayed, now my covers won’t lock in place. So you might be wasting your money.
Probably just a little material on the rim of the cut out, should be able to just dremal any excess material.
I will just trace the outside of the plug and clean off the linex. the big hole is awful looking
Heads up, I had my Linex liner put in last monday. My covers were there when i picked my truck up, but by the time i got home, they were no longer in place. I put them back in place several times, but they still continue to just come loose everytime I drive my truck.
That’s my experience as well, I will not trim the line x and have learned to live with the hole. I did consider applying jb water weld to the covers from the back side. That’s still up in the air.
I had both my bumpers linex on my 2011 Ram and I predrilled and expanded the holes by 1/16” to 1/8” therefore not having to cut away at the linex and exposing the steel to fit all the screws and bolts
Most likely they snapped off the tabs that hold the covers in place, probably because the tabs wouldn't snap into place once the linex was sprayed.
