I use 95 in my truck.My engine has been running on it since day one.There’s no harm in using higher octane fuel.
2019 ram limited
(KUWAIT City)
There's no penalty for going over.I buy all gas at Costco and the choices are 87 and 91, so I suppose it's better to go over the recommended octane rather than under...?
I use 89 consistently. They only penalty to going above 89 is price and you get nothing more for it.
But from what I know, if you go over 89 at shell, you have more detergents in the 93 so your engine is more cleaner in the long term compared to 89. So there is something more for it. Whether that’s a small or large thing.I use 89 consistently. They only penalty to going above 89 is price and you get nothing more for it.
There is more than enough detergents in the 87 and 89 that 93 will do nothing to make a difference. 93 actually negatively impacts fuel economy in our engines and pinging should not be an issue either with 89. Your money so buy what you want but you are WASTING money using 93...it's all marketing my friend...all marketing.But from what I know, if you go over 89 at shell, you have more detergents in the 93 so your engine is more cleaner in the long term compared to 89. So there is something more for it. Whether that’s a small or large thing.
It's really not about the money. 93 is proven to provide worse gas mileage and there is absolutely ZERO benefit to using 93 except for the fact that all of the marketing the gas companies are using make you think you're getting more for your money than you are. If a vehicle doesn't require it, then there is no benefit to using it. I make a great living and money has never been a concern for me (thank GOD), but I am also wise in how I spend itI mean, truthfully, if you’re worried about “wasting” $5 on a filled tank, you’ve got much bigger financial issues.
I get my gas at Costco and always get 93. For the sake of 20 cents a gallon... I’d rather have that extra peace of mind! I like to give mine a good beating, especially with my new exhaust, so why not...?
It's really not about the money. 93 is proven to provide worse gas mileage and there is absolutely ZERO benefit to using 93 except for the fact that all of the marketing the gas companies are using make you think you're getting more for your money than you are. If a vehicle doesn't require it, then there is no benefit to using it. I make a great living and money has never been a concern for me (thank GOD), but I am also wise in how I spend it![]()
First of, premium at COSTCO is NOT cheaper than 87. It may be close in cost to 89. If you can buy 93 at the same price as 89, then go for it. Some say that 93 is harder to burn and can result in poorer fuel economy. Premium gas must be, by law, at or above 91 percent, although you do also see 93 percent octane ultra-premium at many stations. Octane does not offer any better fuel mileage, increase engine horsepower, or make the engine start quicker. Higher octane only reduces the likelihood of engine knock or ping. 93 won't hurt anything...and my comments began regarding the comment made above on additives. Buying 93 only to get more "additives" is a BIG waste of money and totally unnecessary. If you are "concerned" about your fuel, then run Chevron Techron, or your favorite additive, through your tank at every oil change and it will make you feel better. All high-quality fuels have additive packages that are more then enough to keep injectors running clean regardless of octane rating.93 proven to be worse gas mileage in what way?
If he gets his gas at Costco, his only choice is regular or premium, and since premium at Costco is typically cheaper than 87 at regular stations it makes sense to use it, since you will be at least meeting the recommended 89 octane.
Your ears can hear how well your gas mileage is doing???My hemi still pings very slightly on 91 octane when working hard (pulling trailer up a steep hill, for example). Which means, 93 would still be a benefit.
There is no way on God's green earth that someone is going to get less MPG in these hemis running 93 octane.
If you have proof to the contrary, by all means share it. Otherwise my ears tell me a completely different story.
