emmittboys
- Sep 3, 2020
Have appt. to get mine done Oct.9th. Has anyone done this?
I want too, what was the cost to make this happen?Have appt. to get mine done Oct.9th. Has anyone done this?
What are they charging you for the switch?Have appt. to get mine done Oct.9th. Has anyone done this?
i was told the tank was $360 and they would do the install for $300. Just dropped truck off will let you know.I want too, what was the cost to make this happen?
Sent from my SM-N976V using Tapatalk
Hope you don't run into problems if they don't change the pump. Pump is different between 23 and 33 gal.i was told the tank was $360 and they would do the install for $300. Just dropped truck off will let you know.
this is the same place i bought my truck from hopefully they would know that.Hope you don't run into problems if they don't change the pump. Pump is different between 23 and 33 gal.
How did this turn out? Was the pricing correct?this is the same place i bought my truck from hopefully they would know that.
It'll fit. They just didn't want to put in the amount of work it would take to do it. The 26 to 33 gallon is relatively simple, the 23 to 33 takes a lot more effort.they just told me it wouldn't fit !!!! i found that strange they call me and told me they could do it and the prices. Im disappointed but what can i do. Live with it. I think its crazy that you sell a truck with a 23 gal fuel tank !!! But other than that i love the truck.
that is my thoughts alsoIt'll fit. They just didn't want to put in the amount of work it would take to do it. The 26 to 33 gallon is relatively simple, the 23 to 33 takes a lot more effort.
Added expense for consumers? If you look through the thread I linked above you can see a lot of the parts are different.This makes no sense….why would everything be so different?
