Defogger wire location
mike_ct
Just posting for reference in case it might help someone else.
I located the rear glass defogger on my big horn. It’s a high current relay output. I tapped it to provide power to the heated glass I’m putting into my big horn non heated tow mirrors.
You take up the driver sill plate, pull up carpet and open the plastic carrier, and there are 2 harnesses. There is a heavier blue with white stripe. This is 12v when rear defogger is on.
I just made a ground to a part of the metal dash.
Where did you order your mirror glass from and do uou have a part number
Where did you order your mirror glass and do you have a part number
Also curious on this as I just sadly found out mine are not heated as well..
Part number for glass? Why divulge this information and then provide zero reason or info as to how you did this
