Post pics of your Ram!
Right after I had the 35s installed on the factory 22” wheels. No lift; just a front leveling kit.
What a gorgeous set up! I’d like to get the 35s tires, however, as newbie, don’t know if the lift or levelling is required for that. Could you please educate me please if the these tires will be fine without any levelling or lift(not a fan of either). Thanks! My truck is 2020 sport/rebel 1500 with 22 stock wheels.
Neighbors did some diy spray painting that ended up with over spray all over my truck. I clay barred it today.
Sent from my SM-N986W using Tapatalk
My 2020 Laramie, nearly bone stock except for painted tow hooks and front air dam delete. I'd also post pics of the Limited but it's a little dirty LOL...
Good looking truck! How’s the ride with the fox coilovers? Any rubbing issues?
Thanks! I haven’t been able to get off road yet but I can feel the difference in the Fox coilovers just daily driving. Very smooth over bumps and despite what some might say feels like a very cush ride. So far happy with the upgrade. Yes, had to trim the left wheel liner...took about 30 minutes and good to go.
Very nice! I bought pretty much the same truck, but shortly after buying it, I swapped out the 22" rims for some 18" Rebel rims due to the winters/mild off roading I sometimes do.
Nice! I planned on doing the exact same thing, I'm looking for a set of Rebel take-offs in my area, but no luck yet. Did the ride improve with more sidewall? What did you do for speedo correction? (assuming those are 33s). I'm going to install the splash guards too.
Traded in my 2019 Laramie (purchased 7/18) for a new 2020 BTS. Details in signature. Love it!View attachment 69310View attachment 69311
How much lift did your suspension give you? I just did a 2 inch level on the front. Stock height in rear. I have similar wheels on order and I’m looking at tires. Wondering if I’ll be able to fit those falcon wild peak in a 285/75R 18 in the wheel well. That ends up being a 34.8 inch tire.
In metrics, that is my tire size as well. The front coilovers provide 2" of lift over stock suspension. My truck came with the ORG springs so it already had a 1" lift. Essentially that meant another additional 1" when my coilers went on. My wheels are zero offset and I think I would have had more rubbing issues if I went any further out. I'm no expert when it comes to offsets, backspacing, etc.
2020 Laramie sport 4 x 4
In metrics that is the size of my tire. It gives both on my sidewall. My suspension gave me a 2” lift over stock. I have the ORG rear springs which provides 1”. Wheels are zero offset and I did have minor rubbing so I spent about 30 minutes per wheel well trimming, and all is good. Hope that helps.
