Any way to know payload and towing capacity without looking at door jamb?
jastevenson
Hi all,
Will be ordering a Ram this week. Am playing around with different options and while I don’t tow much, I don’t want to end up with a vehicle that has the towing/payload capacity of a Honda Civic.
Is there a way to find out my towing and payload info before I place my order?
Thanks!
There is a door jam thread around here somewhere with many different configurations. I can tell you that my lightly optioned Bighorn is 1794 lbs. As you get into Limited dual sun roof territory you're looking at 1000 lbs
You can try to find a similarly equipped truck from the online shopping tool and punch the VIN in HERE using the "Lookup my vehicle" link.
My mid-level Laramie as seen in my sig is 1615. Though I have not weighed it since adding the extras
Ramtrucks.com, search for towing capacity. There is an easy calculator that gives it to you. https://www.ramtrucks.com/towing-guide.html
Do not use that. It's nowhere near accurate. I can get it to say a Limited has 1840 pounds of payload. There's not a Limited out there with 1840 payload. That's just the base calculator without any additions on it.
Definitely misleading. It shows a Tradesman and a Limited with the same payload
I would think having the payload capacity of a Civic would be sweet! Might have to upgrade to a HD though. :)
That ia the curb weight...not the payload...oops...maybe I miss read you you mean you want the payload capacity to haul a civic. Lol
Sign up at mopar.com. When I log in my dashboard tells me my payload and towing capacities. This is for my Laramie...
