Tow Hitch Mounted LED Lights
JamMastaJ
Houston, TX
I would like to order this tow hitch mounted led light mount to use as reverse lights.
https://www.ebay.com/itm/Tow-Hitch-...775771&hash=item1a558bf568:g:SXsAAOSw44BYPmE4
Is it safe to use a 7 pin trailer towing connector to power these so I don't have to cut and splice wires on the truck? Is there anything I need to watch out for such as amps or wattage? Please see video below
It may depend on the truck, but I read a review (via Amazon or eBay) on a similar hitch-mounted light that complained about the truck reading the light as if it were a trailer, and giving some warnings as a result...just FYI.
Just curious, did you end up pulling the trigger on this? I have a super dark driveway and when I leave for work in the morning the back up lights aren’t sufficient in the rear view camera.
Have you replaced the backup light bulbs with leds yet? Easy mod, $10 or less for the bulbs. There are threads on it here give me a sec...
I did order and install the trailer hitch mount along with some cheap senlips led pods off ebay.
https://www.ebay.com/itm/2-Tow-Ligh...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
https://www.ebay.com/itm/Led-Pods-S...ShippingMethodStandard!77584!US!-1:rk:19:pf:0
The best $40 i've spent. Excellent lights and mount fit perfectly. I used a 7 pin trailer end replacement to wire my backup lights and bed lights using the leads from the trailer harness.
https://www.walmart.com/ip/Packaged...eplacement-Auto-Part-Easy-to-Install/17355689
There is an AUX lead that has constant power on the trailer harness which I wired to a toggle switch in the bed where the OEM led light should be installed. I can turn on and off the lights as I please even without the truck being on. I wired the backup light to the reverse light lead in the trailer harness which powers the led pod lights on the hitch mount. There is even a ground provided on the trailer harness so there is minimum wiring, effort and time involved with the installation.
  • hopkins-7-way-plug-wiring-diagram-7-prong-trailer-wiring-diagram-inspirational-trailer-plug-wi...jpg
