Fog Lights Not working but work when turning
yaksushi
KY
If I try to manually turn on the fog lights "with the headlights on or parking lights on" they do not turn on but I can see the fog lights turn on with I make a turn with the headlights on. What am I missing, is this a bug or am I a moron who doesn't know how to push the fog light button properly?
With your lights are on are the rest of you abot just to push the fog light button and they immediately come on?
Make sure you push the fog light button, it can easily be confused with the rear cargo light button.
Was about to mention that. Fog button is in the middle of the round switch for light. Top portion of you have a cargo switch in that spot too.
Thanks all for the suggestions. I'm going to have to bring it in to the dealership. The fog lights work when turning like I stated earlier, they also work if you push the fog light button before turning on the lights. But if the lights are already on and you try to turn the fog lights on they don't turn on... Something is up with the wiring/signal etc.
Any chance you have Tazer installed? If so unmarry the Tazer than remarry tazer to the truck.
Had to look up what that was and now I want one. I don't have one hooked up.
again,look at your settings. You can set em as turning light aids,when making a turn at 15 mph or less.
Turn them off auto, and touch the top button on the touch lights switch. Bottom half is cargo. Does the green light come on the dash?
My guess is your high beams are on?!?! I found this out over the holiday weekend when I went to the cabin and had to use my high beams, I noticed when I turned lights would come on to aid in the direction of that turn
No dealer said it was a bad wiring harness.
How much did it cost for you to get this fixed? I'm having a very similar problem. Keep pressing the button but no light on dash or anything. Randomly at night turning I'll see just the left or right come on randomly. Looking for the "turning light aids" setting now.
