Wheel Brands/Models That Fit the 5th Gen Rebel
4XPEDITION
Hi all. I am back from my adventures and would like to get going lifting my Rebel. I want to put on 35s and, as you all know, there are very few brands that currently make anything smaller than a 20 that will fit due to the break size. I would love it if people would share with me what brands have wheel models that will fit. We really need a full library here to choose from that members know that work. I know there are a few threads talking about this but I'd like a quick library to choose from. Anybody want to share? And, if there already is one, please send me the link.
U
User_21361
Guest
Fuel Rebel 18s -12 offset
Currently running the stock duratracs but will be moving up to 35s soon
Downytide
Ontario, Canada
Fuel, KMC, XD, Niche, American Racing, Rotiform etc is all distributed by Wheels Pros, which a lot of them are produce in same facility, that means most of their 18"s have same clearance, you can go on their website to find out what fits our truck, they tend to be in 18x9 ET12, ET0, and ET-12 or even lower.
I like dealing with them because its fair price and there's life time warranty on the load range.
I have KMC impact 542 18x9 ET0 on 285/75r18 (aka skinny 35s) Yoko X-AT, they measure true 35" actually at 35.1" OD
There are also others, but for 18"s you have to watch out the wheel weights up front, they may get real close to the calipers and cause them to rub and fall off.
Maddog88
All 18” Methods fit just fine. I have Method Mesh 18x9 -12 on mine with Nitto Ridge Grapplers 35/12.50r18. I did some very very minor trimming to the small mud flap. Barely enough to even matter.
Also, the suspension has been upgraded to Falcon Sport/Tow/Haul leveling system. This would be a good upgrade for you since you are running around with a hell of a lot of weight in your bed.
silverWS6
EPTX
Method 312's with +18 (18x9), driver side fit by the hair on my chiny chin chin and passenger side needed some cleaning up on the caliper.
antwon412
Fuel Tactic. 18 x 9 +1 offset.
Falken Wildpeak 285/75r18.
1090BB03-1899-409B-B547-076DA79850AA.jpeg 3D571B6C-2713-41B0-BDF9-97D2601A6D4F.jpeg
antwon412
Correct. It has the ReadyLift 2” level kit. New UCAs as well since I was in there. Not necessarily needed with only a 2” lift/level but I wanted to play it safe.
Pjwishlist
Can you show a side shot? I have been looking at Methods, but am kinda lost when it comes to offset and backspacing etc. I want to get it right the first time. Plus, I want them to be at or near the edge of the wheel wells. The stock look is lacking.
nabatron
finally got my falcon lift and wheels/tires.
Went with fuel zephyr bronze 18x9 -12 offset
Tires are nitto ridge grapplers 33x12.5 talked to the guy at the shop and said if I went with 35s it would rub and would have to trim which I didnt want to do.
Also went with faclon level lift.
nabatron
Also I like the way the new rock rails/steps look on the new trx wonder if they are compatible with our trucks.
ReLLIK75
I've got Fuel Rebel 20s. Wanting to change from Nitto Ridge Grappler 305/55 to KO2 35x12.5. Will they fit? Or am I better off with the KO2 295/65? I really like the width I've currently got, but also looking to fill in the wheel wells a bit more. I found a software mod for the air suspension that the dealer can perform to lift the front another 2". It's currently at the dealer right now and I'm waiting to hear whether they will do it and how much it will cost. Last option is the Revel/Daystar kit. 35x12.5 HAS to fit with the Revel/Daystar kit installed???? Right??? IMG_2739.jpeg
