500hp bolt-on list....go!
Streetsweeper
I'll be getting a local custom tune. Looking for bolt-on recommendations to try & hit 500hp NA.
Bolt-on? Unlikely. I’m thinking the experts on this forum will confirm a cam swap is needed...
Full bolt ons and a custom cam, heads, etc will not get you 500whp NA. My 4th gen was full bolt on and a custom grind cam. You MIGHT see 450whp NA. You’ll need a good set of heads, 6.4 truck intake manifold and a good size cam.
Agree with you! With that said, FBO & custom cam with hemi tuner you will have a very quick daily driver. That most wont even see coming.......sleeper ftw
They make a stroker kit for the 5.7? Sounds like you need a 392 crate motor to me
Turbo is the way to go. Makes power from 2K+/- rpms and up. Can't beat turbos.
