Shives
Looking for a quad cab sub box. Prefer single.. cash in hand. Lol anyone have any leads? Everything is for a crew cab.
Well, thanks! I’ve done this. Most post lead to a dead end, and folks also don’t go back to chime in what they have used. Plus a ton of posts are dated old, so... New information might be available. Not like I’m asking “how do I add air to my tire”Been covered in many threads - this will get you started:
Search results for query: Quad cab subwoofer box
5thgenrams.com
Welcome to the hunt for a box! I’ll try and keep this updated as I find anything. Currently a place in CT is making boxes for quad cabs... Soon as new drivers come in.2nd this with current info. Also looking for options/locations used.
Same... I have not tried any box, at this point about ready to buy the stock HK sub and hook it up.I don't need crazy bass, has anyone tried something like the Sound Ordnance B-8PTD or other all in one small sub/amp combos?
DO IT and let me know the results.Same... I have not tried any box, at this point about ready to buy the stock HK sub and hook it up.
Hey bud. Wasn't sure how to tag you in my post at the time, but I posted my setup. Hope it helps.Looking for a quad cab sub box. Prefer single.. cash in hand. Lol anyone have any leads? Everything is for a crew cab.
xxxtreme did you use a line output converter to get signal to your amp? trying to figure out where/how to get my 2 channel line output converter hooked into the 6 speaker factory system.Hey bud. Wasn't sure how to tag you in my post at the time, but I posted my setup. Hope it helps.
Hey. I used the Pac amp pro and the anc bypass module that plugs directly into the back of the radio keeping all factory buttons usable without cutting any wires. It's been like a month and still working flawlesslyxxxtreme did you use a line output converter to get signal to your amp? trying to figure out where/how to get my 2 channel line output converter hooked into the 6 speaker factory system.
Thanks for posting this information and clear photos!I literally looked everywhere...
Hey. Sorry I don't have photos of the amps. I pulled out the back seats and secured the 2 amps to a piece of plywood then to the driver's side rear of the cab. Sordy I'm so late to answer. Just saw this.Thanks for posting this information and clear photos!
Do you have any photos of you amplifier(s) installed?
Does it slide around? How does it stay in place? How much room is there between the grills and the seat bottom? Is it squashed up against it? Thanks.I literally looked everywhere and could not find one for the quad only the crew. I really wanted one from fox acoustics but they wouldn't make one for the P3 12" shallow mounts I have. They do however have a really nice box for 10's. I took a chance on a company I'd never heard of out of California called ground shaker. I have 2 12s under the seat of my quad cab and it sounds great, quality is great, shipping was great, and it was only like $210. I've added pics of the fitment. Even with the speaker grilles it fits perfectly. I do have the weather mats installed which prevents the box from going back maybe another inch or 2. But works great I have no complaints!
