RickWaz
THANKS for the info & tip on powering it, RamVadar! I just may try that same setup.I decided to bypass the truck battery and run the wires inside the center console. I hooked it up to an 11 amp hour battery pack because I want to use parking mode and not worry about draining the truck battery. It works out great because there’s 120 V plug in there so the battery pack is charging when the truck is running. Everything is totally hidden when the drink holder tray is slid all the way forward![]()
