Which Grille is this
UnloosedChewtoy
5thGenRams Supporter
South Dakota
Welcome aboard!
I believe that is non-Longhorn/Limited grill, and I believe the non-chrome version is painted to match the truck (or whatever color you want). Unless, of course, you find someone selling a used grille that is already painted.
Part # I have found: 6000185AF
Do not buy a grille off a Longhorn or a Limited, as that grille will be different. The Longhorns and Limiteds have different headlight housings than the other trims, and the grilles are slightly different.
Wheeler
It is laramie trim grill. Blacked out/night edition.
Laramie is best looking grill and head light of all trims.
Scram1500
It looks like Built To Serve, but I think those are satin/flat black
jamaicanbro1
Washington, DC
Welcome aboard!
Thanks for the welcome. I have been lurking for a while and about to put an order in for a 2021 Laramie Night Edition, to replace my 17 Rebel, but saw this grille on a Bighorn. It was a one off as all the other Bighorns did not have that look. I would like to replace the Laramie grille with this one.
UnloosedChewtoy
South Dakota
Yes, in theory it should fit, as long as they didn't change something "behind the scenes". Wouldn't really make sense if they did, but wouldn't be the first time it happened.
Here are some pictures of the built-to-serve grille. The others are correct, that is what it is.
Wheeler
Ram is really good tweaking little color combo and giving whole new name. I like build to serve color combo. Here is my truck and it is Laramie trim. Second picture is next to my friend's Laramie sport same grill different color combinations. I believe you have Larimie night and one OP is questioning is Laramie build to serve edition. IMG_20200110_094738.jpg IMG_20190917_083834~2.jpg
puba08
Definitely the BTS grill
Fishwiz
Ram is really good tweaking little color combo and giving whole new name. I like build to serve color combo. Here is my truck and it is Laramie trim. Second picture is next to my friend's Laramie sport same grill different color combinations. I believe you have Larimie night and one OP is questioning is Laramie build to serve edition. View attachment 67179 View attachment 67180
Correct that it is BTS grille (as already identified). It is not a "Laramie BTS" though. All BTS trucks are built on a Big Horn.
du4life25
Is it possible to get that black grille w/ the black "RAM" on a North Edition instead of having the chrome "RAM"?
Wsmith
Northern Illinois
Looks exactly like my bighorn night edition. I think any black grill would fit on a tradesman up to the longhorn, starting with the longhorn the projector housings are smaller.
UnloosedChewtoy
South Dakota
The Big Horn night edition grille is different. First picture below is a Big Horn night edition, second is the Built to Serve, just like the picture the OP offered.
Grilles on the Tradesman to the Laramie are interchangeable to my understanding. Longhorns and Limiteds, as you stated, along with the new TRX, use the smaller/skinnier projector LED housings (rather than Halogen or reflector LED), and therefore have different grilles.
Styling wise, the Limited's black appearance package sorta combines the two grilles. It has some of the horizontal slats (or whatever you want to call them) of the night editions in lower trims, with the "filler" panels from the BTS.
