SilverNight2020
It might require more wire to be run to the fuse box and battery, but there are small opening on the bottom of each side of the shutters where I ran my wire through. I have had no issues with the wires being in the way, as they stay away from the active shutters. I mounted my DRLs on the lowest rung of the grille, so I was closer to the openings than if they were mounted on top like yours. Fun thing is, I recently just discovered three of the six LED bulbs are blown out on the driver's side light, so I am ordering a set of 24" LED strips with sequential turns to replace the ones in the picture. Sounds like a fun weekend project.For now I ran them through the very top shutter leaving some slack in the line for when they do close, only because I was in a rush and didn't want to have to take the whole grill off, but if it becomes an issue then I'll take the whole grill off and go from there.
