Anti Theft Code. HELP !!!
Chillz
I took the battery negative terminal off the change my headlight and now I am being asked for a anti theft code..
gHiDoRa
Elvis Presley
never unplug mine yet but i know alot peps here already done that but never hear anybody saying anything about required anti theft code after. I would suggest you contact your dealer for that code.
whetrick1
Did you get that issue fixed ?
Mine did that once when I went out to start it up. Called the dealership and they had to have it put on a rollback and took to the dealership. Come to find out the pcm lost all of its programming and had to be reprogrammed. The dealership ordered me a new pcm to replace it with. Drove the truck until it came in.
froy119
NC
Mine won’t even turn on. I disconnected negative terminal and now it won’t crank and anti theft code is on.
Sascwatch
You will probably to have to get it into the dealer. Try pressing the start button with your key fob and see if it’ll start, I was told this is how you can start the truck if your fob battery dies.
lmattus
Check the fuses boxes in the hood , i belive its a 10 amp fuse 35 have to be inserted
whetrick1
That's what mine did, it kept asking for security code. I called the dealership and they told me to have it towed in. They reprogramed the pcm and everything was back to normal. Then he told me he would order me a new pcm because he didn't like the idea of the customer riding around on a pcm that might screw up again. I told him I would drive my truck until the new one came in. I don't like driving loaners.
Kur8ness
If you cycle the run acc push start a couple times it will go away
