I ordered a Pedal Commander the other day and went out to install it yesterday. I was unsure on how to disconnect the wire plug from the accelerator, so I quickly looked it up on YouTube. One guy just said to pull out and then up. So with that, I did was he said and ended up pulling more of the plug off that I should have. Yes, I do realize now what he meant and it is very easy, but wasn't clear from the start.
Anyhow, I had to unbolt the pedal and take it out to put the other half off the connection back on the pedal. I was so pissed at myself for doing this because I normally don't screw up things like this. I eventually got it back in and reconnected everything back to stock. My first try didn't work because my dash lit up with errors and the accelerator didn't work at all. Ugh....talk about panic. I pulled the pedal back out and reassembled what I did. Thankfully, it worked. However, my check engine light was on. I disconnected my battery to clear the code that I had thrown and now half of my UConnect options are gone. WTF. I guess from reading on here, this is normal and have to wait a few hours for everything to return to normal. I will check this morning and see if everything is back.
Now for the question, should I even bother installing the Pedal Commander? Ugh....please no "you're and idiot" comments. I am beyond pissed at myself for doing that.
