My dash keeps alerting me that my rear right tail light turn signal is out but it's still working?
Try to unplug and plug back connector? Maybe it's just a little loose and when hitting bump it trigger the warning code. I put Stake Pocket hole cover cap on my Ram. If you look on the stake hole, you can see the connector. So maybe water did some damage there.
Keep getting a notice but when i check all lights are working fine...? any thoughts?
Sorry for the trouble, @MValdez! If you are not able to determine a solution based on suggestions from fellow forum members and you decide to address this with your Ram dealer, please be sure to follow up with us via private message. We would be more than happy to escalate your situation to a specialist who can work alongside you and your dealer while your truck is in service.
Mark
RamCares
Double check the cab mounted brake light. On my 2015 the warning for a burnt out cab mounted brake light was always showing as a right rear tail light. No sure if it's the same with the newer models.
You know what I'm glad you mentioned this as i did swap out the bulbs in my 3rd brake light with LEDs. Gonna go check in a min. TY
