5thGenRebel_AMK
does it say that somewhere on the bottle? I've always understood that you should put the most protective layer down first. in this case ceramic is much stronger than old school wax. that's interesting if they recommend to wax it first. most ceramic/sio2 spray waxes ive seen are effective as stand alone productsJust wipe it a little better...
FYI...I bought the same seal&wax ice....found out it's not actually a wax....you're supposed to use it AFTER you wax. Use the regular "Turtle Wax ICE" spray wax.... you'll be pleasantly surprised.
Or try the chemical guys Blazin Banana spray wax...that's decent stuff too.
