Gooseneck Hitch
wtyer
Has anyone installed a gooseneck hitch in their 1500? Are there any pros or cons to installing one?
Does the 1500 even have enough Rear Axle Weight Rating (capacity) for a 5th wheel/goose neck to even be worth it? Didn't think there were that many light 5th wheel/gooseneck trailers out there.
There aren’t many but there are a few
Actually there are more all the time using the Andersen Ultimate going through our RV park. It is for conventional fifth wheels to be towed by trucks with a gooseneck in bed ball. Check it out.There is also a Companion hitch for the in-bed ball. The reason I went this way is that when I purchased my Ram, rails were not available for the 5th Gen. trucks yet. Now that in-bed ball to rails are available I may get the rails so that I can use my conventional slider fifth wheel hitch. That way I can get the pivot point lower and the pin a little more forward. We'll see. The setup I have works well and tows nicely.
What are you towing? Pics?
It’s possible if you load the truck light. Until the urge to get a bigger trailer happens
@Trooper4 have you scaled your rig.
I would really be interested to see your rear axle weight.
Setup looks awesome though. You seem happy with how it pulls.
@Trooper4 That's the setup I was thinking to go for but didn't believe it would weigh out; I'm looking up the Sandpiper line and curious what spec / model you're running. I'll likely go a similar route in the next year
