Updated 2" Mopar Lift/Level Kit - Discussion
Well it looks like I found out why I have 2” of rake. I was fine with it until I didnt see the 2nd spacer under the spring seat.
I was under the truck looking at the front bumper valance and seeing about removing it. I looked back and thought “Man my cv angles are flat”. I looked up and saw this...
You have the "AB" kit ? Correct me if I'm wrong but I think the AB kit is updated to work without spacers.This is the AB kit and dosen't come with front spacers.
I think the wording on this listing is the issue. They should’ve said the kit comes with the revised front shocks not spacers. This looks like the same kit I got and the spacers go on the rear coils as that is what lifts the back end, not the shocks.
AB kit has one spacer for front struts instead of requiring two for the earlier kit.
So does the AB kit just use longer shocks and no front spacer? Or does it have longer shocks and just one front spacer?
The spacer is on there, just very hard to see if you don't know what you are looking for.
Im going to get new tires first to see what I end up with. Im still on stock tires so its hard to tell exactly what it would be height wise when everything is done. I was set on 285/65/20 but now Im considering 275/65/20 (The biggest reason is I didn’t realize how much of a weight difference there is. About 14lbs per tire (275-54lbs, 285-68lbs)). It’ll only be about .5” shorter than the 285 so Im thinking I will be around 40” up front since most people are at 40.5-41”.
I have the AC kit.
