Truck dead
Hutch70
So I've had my 2019 limited for a little over a month now with just over 2k miles. This morning I tried to remote start it and all it did was give me one horn honk. Turns out the truck was dead. So I had to jump start it and the check engine light stayed on while I drove around. The check engine light turned off after I let the truck sit for about 30 minutes. Has this happened to anyone else? I'm concerned because the battery died for no apparent reason.
mtehonica
Just had a very similar thing happen. Did you end up getting the battery replaced?
Bwarren2
Anyone put a multimeter on the alternator?
mtehonica
No, didn’t have one handy but dropped mine off at the dealer today to check all the codes it through, test the battery and fix a couple other issues since it was the first time I took it in since taking delivery.
mtehonica
Update: Dealership wasn't able to find any problems or draws and the battery tested good so "no trouble found" :confused: Guess I'll wait to see if it happens again.
mtehonica
We've had a few reports of this happening when the radio does a scheduled update but sometimes hangs and runs all night as an FYI.
Thanks, that’s good feedback. I actually kind of chalked it up to that already. The radio never prompted me for the 12.20 update that released a few weeks ago, but I checked and it got installed (before ever going to the dealership). So I’m thinking it somehow updated, hung or otherwise did something to drain the battery. Wish there was a way to confirm that for peace of mind.
Neocane
Will the radio start an update if the truck is off?
mtehonica
No, the intended operation is suppose to be to prompt the user to update now or schedule the update later, and its suppose to update even if the truck is off. But with all the bugs in the new Uconnect, I wouldn't be surprised one bit if a radio tried to update without user interaction and hang or whatever and kill the battery.
Neocane
That’s odd. It would be like your computer turning on by itself to run an update from windows, but that doesn’t happen.
John
Did the update fix the low radio volume on the Limited HK sound system??
John
Dkwatts1522
I haven’t had this problem with my Ram but we did this spring with my wifes 17 Ford Fusion. Sync 3 was trying to updated and keep running until it killed the battery. Dealer had to flash computer to fix.
Neocane
Does the radio use your homes WiFi if it’s close enough to connect, or the Nav signal? I imagine if you set it up that WiFi would be much quicker.
Dkwatts1522
My wifes Ford uses wifi but I believe the Ram uses a satellite signal. I haven’t had to connect it to my home network like I did with the Ford.
VectorZ
Alaska
I think it's the built in cellular. We have no satellite coverage here in Alaska, but my truck has done its OTA updates.
ExcursionDiesel
Uconnect uses Sprint 3G...at least that's the connection on the older Uconnect systems. I've had updates that hung due to poor signal strength.
