Rhombus
Has anyone identified which AC hose to clamp on the Ecodiesel? SOOOOOOO many pages in the AC hack threads.
Thanks.
Thanks.
Mine was fine before, i thought id try it out, thats why i just used a clamp instead of a valve of some sort.My AC is an icebox, so glad I don't have this issue.
Yeah something is up with yours.I wish this made mine an icebox. My temps were 58-60 before the clamp, now about 52 with it. So, it helped, but still not enough. I had the system checked by the dealer and they added a little bit of the 1234YF refrigerant. There's still something wrong........but it has been 110 plus here lately. Even in the morning when its low 90's, I still only get 52deg out of the driver's vent.
I used the same clamp as recommended by KNGSNK11 and my temps are now in the low to mid-40’s even when it’s 100+ outside.Yeah something is up with yours.
I have been working in the Houston area and its been hot and muggy, and when I do check mine its always been in the lower 40's and that sitting idling the truck at lunch.
My driver's side averages around 50 without a clamp (I've seen it as low as 48). My passenger's side (of the center stack) will hit 42! Note: These temps are achieved with the system set at Auto and 70 driver / 72 passenger. So I agree with @KNGSNK11 - that doesn't seem normal/right.I wish this made mine an icebox. My temps were 58-60 before the clamp, now about 52 with it. So, it helped, but still not enough. I had the system checked by the dealer and they added a little bit of the 1234YF refrigerant. There's still something wrong........but it has been 110 plus here lately. Even in the morning when its low 90's, I still only get 52deg out of the driver's vent.
www.motor.com
