Window Sticker Question
Rebel20
I ordered a Rebel about 8 weeks ago in granite crystal/ black two tone. Found out today that it's been built and is in transit as of today. I got a picture of the window sticker and it lists the exterior color as granite crystal metallic clear-coat exterior paint. I dont see anything listed about the two tone paint option on the sticker. Should it be listed on the sticker? Sure hope they didnt make a mistake. I checked the build order prior to the dealer sending it and it was definitely on there. For you two tone guys please check your window sticker and see if it lists two tone paint as an included option. Thank you in advance
My window sticker lists the two tone paint option on the lower left hand column as a $250 adder
Here is the window sticker. Unless I'm missing something, I'm not seeing anything to specify the two tone option.
The first item listed on your build sheet is “Lower two-tone paint” so it should hopefully have it!
i pulled the build sheet of a local rebel which doesn’t have lower two tone, and it doesn’t list the option on the build sheet, so it appears your truck was ordered correctly and should have lower two-tone paint even though it doesn’t show on the window sticker.
Great. I can breathe a sigh of relief lol. Now looking forward to taking delivery! Thank you!
That's because you have a Laramie, where two-tone is an option. On a Rebel, it comes standard with two-tone paint - you have to add the monotone option if you want a solid color. That's why it doesn't show on the window sticker. Don't worry, OP - they painted your truck correctly! ;)
