Tonneau Cover?
jback1131
Hello Everyone,
I just purchased a 2020 Dodge Rebel with the " Split Tailgate", no Ram Box. I am looking for recommendations for a Tonneau Cover.
I am looking for a good quality, that can be easily removed to use the full bed.
I greatly appreciate any advice. Thank you
John
Hello
Just search the forum or Google. There are plenty of choices out there! You just have to decide if you want a hard or soft cover and if you want a roll up, folding cover or removable.
Sent from my LM-V405 using Tapatalk
I put the Peragon on based on reviews and photos from this site. I had an access lorado on my silverado and really liked it but wanted a hard retractable this go round. Its really all you preference. Every single one has a plus and minus. chose the one you like the best or fits you use the best.
There are literally 47 posts about tonneau covers here on this site...use the search window at the very center, top of the site...
I had the Extang Solid-Fold 2.0 installed on two previous trucks, and wanted a flush mount this time, but the options are limited due to the bed support brackets near the cab. After conducting some research on resized brackets, modifying tracks, etc., I ultimately went back to Extang, which works with the MFT.58F0550C-8543-4F97-B933-791966710298.jpeg
Looking at picking this up today, I too have a Rebel with MFT - Looks great man! Couple quick questions for you -
How's the water repellency? Can you hear it over bumps?
^^^ I never had any issues with water. It’s solid- no creaks or squeaks with bumps...
I had the Extang Solid-Fold 2.0 installed on two previous trucks, and wanted a flush mount this time, but the options are limited due to the bed support brackets near the cab. After conducting some research on resized brackets, modifying tracks, etc., I ultimately went back to Extang, which works with the MFT.View attachment 58470
I didn't quote, please have a look at the post above!
you rock! thank you sir. Do you have the tie downs rails?
  • Like
Reactions: STR
^^^ No, just the 4 OEM tie downs toward the bottom of the bed, and I also installed the AMP Research Bed Extender, which fits under the cover.
Like other's have said, penty of options so just pick one.
Paralysis by analysis is real.
Cheers,
Cheers,
Actually, no there aren’t. The multi-functional Tailgate or MFT as you would see in posts, prevents most Tonneau covers from installing due to a bracket added in the bed. I wish I had paralysis from analysis, but there are only a few options without replacing the bracket with an aftermarket one, which unfortunately voids warranty.
  • Like
Reactions: STR
Amazing! I bought one the other day, mentioned rails should not get in the way. Thanks for the help! It’s hard to find info on MFT Tonneau options
Actually, no there aren’t. The multi-functional Tailgate or MFT as you would see in posts, prevents most Tonneau covers from installing due to a bracket added in the bed...
^^^ This...
Hello Everyone,
John
Gator quad fold (hard cover) gives you access to whole bed.
Check out this thread:
tonneau covers that work with the multifunction tailgate?
Site indicates that it’s not compatible w/MFT... Do you have it installed w/the MFT? If so, pic of the install would be great!
^^^ That’s OK... I really like the Gator Quad Fold. Wish it would’ve worked w/the MFT (y)
I received my cover today...looks awesome, but the back hinge closer to the tailgate doesn’t sit flat...Did you experience this as all? There’s a screw in there, should I play with it?
