First tow with my 19 limited air ride
Txd33r
First tow with the 19 limited. I didn’t go too far about 600 miles round trip with about 3000lbs is all. Towed fine I love the suspension auto leveling it’s awesome. Coming from my f150 it’s comparable. Only very slight annoyance is I can’t seem to override rear sensors for hooking up to the trailer. Also when trailer is attached it doesn’t auto turn off rear sensors like the ford did because of the 4 pin situation. I read that the park sense is automatically turned off via the resistance present in the trailer breaks I believe.Otherwise everything’s great.
That load is easy. I tow a RZR1000 4 seater every weekend for the past year... It's a piece of cake for this truck!
That's an easy load for the 1500. May want to get a larger drop receiver though as the trailer is not level, and putting some added weight on the rear trailer tires.
Agreed I saw that. I have a weigh safe hitch on there but looks like I’ll need to adjust it. I had a touch over 10% tongue weight at 350lbs on but the auto adjust in the suspension still causes it to sit high.
I like the wheels on your truck. Which ones are those?
