Interior Lights not working
DennisY
Sorry, I may have misunderstood the question just now but as I noted earlier in the thread, only the portion you have circled in red comes on in mine.
Loyal Ram
NC
I saw your question about light and I have a question about how much light shoud there be, in my case only part in red has light, the area in green has no light, does it have to be like that or am I missing bulbs inside
Sent from my Pixel 2 using Tapatalk
I am wondering the same thing
Eurosir
The RED area does NOT light up...it is NOT a light. To have all controlled by the doors opening make sure you have pressed the button above the blue assist button.
So what does the red area do than, if it is not a light?
Bik684
I was having issues with the map lights and the tailgate button not working on overhead panel. However the rear window still worked. Took panel off under steering wheel and checked the F33, F31, and F30 fuses. All were good, but just plugging them back in seem to fix the issue. Had some loose fuses under the hood as well. So hopefully that will help anyone having same issues.
I had a same issue today , I checked f 33 and plugged back in and it works Fine thanks a lot
biodiesel
I just took delivery of my 2020 Ram 1500 EcoDiesel yesterday. Everything seems to work except for the interior lighting when the door is opened. I did a quick google and this thread came up. I tried pressing the button that you suggested and it worked! So, I had to register on this site just to say, "THANKS"!
securityguy
North Florida
SWEET...welcome to the forum my new friend!
henshawzm
Mine just started having this issue. Pulled the F33 ... nothing. UGH
RamCares
Michigan
I'm also having the same problem :(
Sorry for the trouble, @henshawzm & @michadoh. Please know that if you have to move forward in addressing this with your dealers, I am more than willing to escalate a case on your behalf so that at the least, you and your dealer have the additional support of a specialist in ensuring all resources are exhausted to address your concerns. Our team is always a private message away.
Mark
RamCares
