Installed the mishimoto catch can with the added drain part. Very easy install with the exception of getting the intake plastic cover back on. Drain part means I can just turn the petcock and have any oil drain out below.
That's what I did to mine when I put it on over a year ago. Got the drain from Lowe's for around 3.00 dollars. Works great and it only takes about 5 mins to drain it.
Installed some new shoes! I didn't want to much taller of a tire because I drive in a lot of stop and go traffic. Went with M/T baha P3's in 285/50 20. Much nicer look speedometer is off 1mph at 55.
What's point of this tires ? You guys working in the oilfields or farmers ???
Installed some plugs I painted the other day to fill in my bumper holes.
Came in a pack of 10 so I just painted them all. Anyone else with Billet Silver interested in 4 of my extras?
Installed CDT HD-690CFS.2 in all doors. Waiting on the JBL’s Club 322F to come in to do the dash and headliner. Also installed the 6.4 intake manifold. I’m going to have to fabricate the S&B air tube to match up to the S&B air box with the new manifold as I don’t like not having the protection of a closed air box.
How’s that 6.4 Intake working for you?
18" Fuel Shok's with stock tires and 2" Readylift level. Also Plastidipped the ventvisors before I put them on.
Are those low profile in channel on your windows and where you get them?
Install was simple. I’ll let you know on the rest if you’re interested. I did the 6.4, ATI damper and long tubes at the same time. However, the person heat coating my headers did not finish in time so the truck is just sitting in the driveway till I get back home to finish it this Tuesday.
Did you do a cam as well? Heard it’s needed for the increase air flow.
  • FM45
