Fuel Rebel -12 Offset, Duratrac 33's 275/70/R18
U
User_21361
Guest
Just got new wheels installed. I haven't seen a lot of posts on these so I wanted to get something out here.
Fuel Rebel wheels 18x9 -12 offset in Anthracite
Stock Duratrac wheels - 275/70/R18
The wheels pushed the tire out by 1.25 inches. It has a much more aggressive stance. I also love the color contrast from the all black stock wheels. The big unknown was how would they work with weather tech mud flaps. The good news for me is that they clear by about 1/2 inch at full lock. The bad news is that I definitely will rub with 35's. the PNW has constant rain, so ditching the mud flaps (especially on a black truck) was not ideal. I'll stick with the 33's for now and maybe upgrade if I go with a full lift instead of a level.
EbAvery
Awesome looking truck, looking to do exact same thing with fuel Shoks. So you just have a leveling kit?
I have a completely stock suspension and concerned if it will rub
U
User_21361
Guest
Yeah just the level. No rub, but very close
EbAvery
It’s close on the mudflaps, not the body I’m assuming? How did you level it, not very experienced lift/level kits.
Jhall
Awesome setup. I just ordered the Rebel in a 20x9 with a +1 offset and 33x12.5. I’m told it should fit without rubbing. If not I guess I will be leveling the front lol!
U
User_21361
Guest
Correct, close to mud flaps. I have Bilstein 5100s on the front. Removing the mud flaps would probably get me and extra 1/4-1/2"
EbAvery
Awesome just order fuel shoks. Also went ahead and order bilsteins 5100, really loving the look of the leveled rebel. Did you just have the stock springs switch over to the 5100?
U
User_21361
Guest
Yes. The install was pretty fast and cheap at a local garage
Bigalh79
NC
Did your wheels come with hub centric rings? I ordered a set of 18x9 -12 fuel wheels and I wasn't sure if it came with them or do you have to order them? The wheels look good!
LaxDfns15
Memphis, TN
Personally on my Level 8's the hubs are like 108mm. I didn't get rings as the wheels are lug-centering, so as long as you put the wheels on well you're set.
sirbojangles
Canada
It will fit I'm running the exact same set up 20x9 with a +1 offset and 33x12.50 and It does not rub at all.
Ramtrx
When I got my wheels they cane with some plastic gun centric spacers. I quickly went online and got aluminum ones made to same specs as spacer needed that was plastic.
Bigalh79
NC
Do you have a link to the ones you bought,I ordered my wheels but haven't got them yet.
Jhall
I’m wondering if I will need to have the speedometer reprogrammed going to this size of tire. I know it’s not much different in size but keep thinking it wouldn’t hurt to pick up the RC programmer.
Ramtrx
Us wheel adapters. They will ask for inner and outer dimensions. Made of aluminum. Came in about 10 days too.
Bigalh79
NC
How did they balance your wheels? I got my fuel wheels 18x9 -12 and they said that they couldn't balance them correctly because of the brake caliper was to close.
Ramtrx
Why would that matter if the tire is off the truck? They remove tires from truck to balance the wheels.
U
User_21361
Guest
The weights are mounted inside the wheel near the outer side wall, if that makes sense. They don't come close to the brakes. It took me about 5 min to even find the so they are very well hidden.
