Installing 35's on a 2019 Ram Rebel
Waydemorris97
Just curious what setups are out there to achieve 35's on a 2019 Ram Rebel. What kind of leveling kit/lift used, type of wheels? Is it possible to fit on stock wheels?
35 Maximum 12 wide can fit Rebel with coil springs without rubbing & any mods, 12.5 wide will rub the small plastic mud flap, As for wheels try to stay with 0 or +1 offset.
i have 35x12.50's on -12 offset wheels on just a level. it rubbed the plastic mud flap and i also had to bend back the metal tab that was behind it. I just sip tied my wheel well liners to pull them back a little and i have zero rubbing
Thank you, now would that require a leveling kit?
Right on, what leveling kit did you choose?
I had my wheels & tires on then a week later i installed the Ready Lift 2 Inch leveling kit no rubbing before and after but the truck needed leveling after bigger tires.
Ok, how do the ball joints and CV angles feel with the ready lift? Did you raise the rear as well? Thanks!
Question is would 35’s fit With the stock rebel wheels and a level?
I am looking at micky thompson 305/70/18
that is a 12” wide
Rides like factory stock, After installing the front leveling kit the truck is equally balanced front & back no need to do anything on back. Back side of the truck was higher from the factory that’s usual in trucks.
I think the MT models you’re referring to will rub as they are wider than 12. Use tiresize.com to identify the tires and exact dimensions.
Ya, and with rebel already an inch higher I was sure it would be fine. I think I'm gonna go with the 305/70 18 and get the 2in level
Do you have stock rebel wheels? Or did you have to change wheels to fit 12 in wide?
