Off Road Springs On Standard Suspension
anyone know where to find them for sale new online?
I guess, that's my issue. Are they sold as a set of (4) with 1 part # or are there 2 separate part numbers for front & back?
The are all sold individually. The rears are much more expensive than the front, for some reason.
From the pics earlier in the thread:
Front P/N 68320249AC
Rear P/N 68262686AB
wow, yea almost double the price for the rears for the few sites I have checked.
Stiffer springs will make the ride harsher. It's physics. So will lifting with 5100's becuase they lift by preloading the springs. Springs get progressively stiffer as they compress. Exponentially acording to their spring constant to be exact.
so then, would there be any difference between the Mopar Fox set up w/ ORP springs vs Bilsteins with the same springs?
There are about 50 different PN's for the springs for some reason. My Rebel springs have different PN's than the ones listed above, but they're supposed to be the same as the ORP from what I can gather. My rears are 68370565AB for both sides, but my rear heights are over 1/2" different. Been trying to find time to go to the dealer to try to figure it out, just haven't had the chance.
I've noticed the same thing, everywhere I look has something different. I just want to compare prices for the Bilstein/ORP set up vs. just going with the Mopar/Fox. See what really gives me the best ride, performance and bang for the buck.
I did orp spring in front with bilstein all around, front set on #5, nothing in the rear just orp coil, still have a bit of rake and up about 2.8 inch front and 3 inch rear from a stock truck, mine is a 2022 ram sport, it rides good, rebound over bumps is better handles great, I also have hellwig swaybar in rear
Sounds similar to mine. '22 Laramie GT sat too low in the front for my taste. I swapped a set or ORP struts on the front, sits perfect now imo, ride is good. Also have a helwig on the rear.
