Locking key fob in truck?
smashweights
D-Lux Apt In the Sky
Curious if there's a way to lock the key fob in the vehicle and use the metal backup key for re-entry only? Reason is I go paddle boarding often and lock valuables in the truck but need to keep a key on me. The board has a small "waterproof" cubbie that fits the fob if I pull the metal key out but I am very nervous if the seal failed saltwater will destroy the fob. Would rather lock the fob and take the key insert if that's even possible. Thanks!
Lil Miss Always Wrong
if you have a rambox you could definitely do it and i THINK even if u left the promimity key IN the cabin, as long as you locked the door with the metal key it should lock no problem...(can't use the buttons i don't think) and if not, just have them make u a cheap $2.00 key at hardware store : )
That's how i did it on my Laramie 2018, i don't think its changed
HMC8403
Chicago IL
I'm currently in a loaner that does not have Passive Entry; never realized what an inconvenience not have it was. Instead of reaching for the remote every time I wanted to lock the truck, I would press the power-lock button inside the door as I would exit. One day as I shut the door the truck honked a couple times; that's when I realized the truck was warning me that the fob was still inside. Cool feature.
redriderbob
Co-Editor & Ram Guru!
Metro Detroit
No, but our long-term Laramie Sport had an issue that would start the truck with a key fob in the truck. Unplugged the battery and left it sit and it fixed it.
Dumpster_on_Wheels
PA
RFID block sounds like a good idea. I mountain bike a lot and fear of losing my keys so I hide them under vehicle. But with passive entry i need to either disable it every time or take the key far away. A lot of spots under vehicle to hide won’t work.
HMC8403
Chicago IL
When I used to deploy I would lock the keys in a hitch safe. Useful for when at the beach or anywhere you don't want to carry the keys with you.
Jtr
Illinois
I just hide FOB in a bush or tree far away enough away from the truck to find it when I return. I'm sure others are like me and we hope we remember where we put it when we return.
Muskiez
Minnesota
This is the single biggest thing I miss about my last few trucks. They were fords and had the keypad on the door that allows you to lock the keys in the truck. Didn’t realize how much I used it until I couldn’t! Love my new Ram just wish it had a keypad
Dumpster_on_Wheels
PA
I was also under the impression if you tried to lick the truck with the fob in the vehicle it will refuse.
Dookie
Prairieville, La.
I lock my fob in the truck all the time, haVE to use the Uconnect app. to lock/unlock. I do have passive entry and is enabled. Leave fob in truck, closed the door and lock with app. locks no problem, then use the app. to unlock.
