The driver’s side rear view mirror is loose and shakes at highway speeds. I can take it to the dealer under warranty but wouldn’t mind fixing myself if easy. It is not loose at the door but where the two pieces join. How do I access? What is the little access panel in the bottom of the assembly? Looks like a push tab but not sure if this is where the bolt/nut is located so it can be tightened. Anyone know?
