Driver Window Issue
janno_napster
Hi Guys,
wonder if you guys having the same issue with driver window when open half way and whenyou close it it goes up a bit and goes down a bit then stop...thats on full auto by the way..
-RotorDemon-
Troutdale, Oregon
Daily thing with mine. Thought it was the mopar in channel deflectors putting too much drag on the motor causing it to think there is a arm or something it's pinching. Took that off. Same thing.
Tried the whole hold switch down and keep holding 5 seconds and up to "re-learn" but that does nothing as well. Left front window only. all others work 100%
RamCares
Michigan
Hi Guys,
I have same issue. It happened everyday.
Hi all,
If this is something you decide to address with your dealers, please do not hesitate to follow up with us via private message for an additional layer of support through that process. We are happy to get you connected with case specialists who can work alongside your dealer to remedy this concern as soon as possible.
Mark
RamCares
Kooch80
Washington
i have the same issue. i have not had the time to address it with the dealer yet.
RamCares
Michigan
I regret to hear this, @Kooch80. If you are able to move forward with your dealer, please do not hesitate to follow up with us via private message. I would be more than happy to escalate a case on your behalf for further support through that process!
Mark
RamCares
RamLink83
I haven't noticed that issue yet, but I have noticed the button is very sensitive and will activate the auto up and auto down very easy. You have to just barely touch it to choose how far you want it down or up and if you press just a little too hard it will activate the auto up/down feature. It's not too bad for me, but my wife has trouble on the passenger side a lot.
