2020 Ram 1500 outside air sound into cabin at speeds above 45
TA2126
I have a 2020 Ram 1500 limited I have what sounds like outside air coming into cabin at speeds above 45 mph coming from the front lower left windshield near inspection stickers. If AC or heat is turned on sound diminished anyone else have these problems
Passengers side?
Do you have the towing mirrors?
No reg mirrors and I did retract no difference. The dealership has it for 8 days and taped it up and only conclusion was adjustable Louver on bottom lower front of front bumper changes out and same noise is still present Wondering if all limited 2019-20 trucks have this outside air noise
There is another big thread with people having similar issues. Apparently these new Rams are crappy when it comes to sealing up the body. Numerous reports of air/whistling noises and water leaks. I just joined the water leak club the other day. Thinking getting a Ram was a bad decision. Mine is a 2020 that is 5 months old.
Where is the water leak
Mine is leaking from the third brake light I think. Headliner was wet in the passenger corner. Also had a drip in the center of the window after I pulled it into the garage level ground. Goes into the dealer for a "leak doctor" to diagnose.
Sounds like a lemon law coming your way
Hi @TA2126 & @RamLink83 - Please know that I am more than willing to escalate cases on your behalf to get you set up with specialists who can work alongside you and the dealer for your current concerns. Our team is always a private message away.
Mark
RamCares
How do I private message
Yes it’s by the inspection stickers in that corner
No members online now.
