Just clean the surface with isopropanol alcohol but for you spray. If you're going to keep them dipped, I would spray 5 to 6 coats.Anything special I should do to prep the chrome hooks?
The light bars ? I was thinking of doing the ram letters in green . I wrapped the calipers this green as wellHave you thought about spraying the bars in the grille that same green?
Sent from my Pixel 2 XL using Tapatalk
No, the horizontal pieces in the grilleThe light bars ? I was thinking of doing the ram letters in green . I wrapped the calipers this green as well
Not a bad idea I’ve had the grille fully apart a couple times such a pain in the a**No, the horizontal pieces in the grille
I think that would look real good. I saw a white Ram with the pieces painted red. Looked real nice.Not a bad idea I’ve had the grille fully apart a couple times such a pain in the a**
How did you wrap your calibers?The light bars ? I was thinking of doing the ram letters in green . I wrapped the calipers this green as well
I do a good amount of vinyl on the side , they make vinyl specific for calipers . 3m and Vvivid . 3m is hard to use , Vvivid is way more forgivingHow did you wrap your calibers?
You can remove them from underneath pretty easy , or pull the bumper . These front bumpers are nothing to remove . But you definitely don’t have to .So how did you guys go about painting them? Did you leave them on the truck and just tape everything off? I crawled under there but can't really get a wrench/leverage on them, the chin spoiler and active air dam are in the way...
Could you link where you get yours?I do a good amount of vinyl on the side , they make vinyl specific for calipers . 3m and Vvivid . 3m is hard to use , Vvivid is way more forgiving
I use oracal sign vinyl for a lot of projects.
What you guys think about color for a flame red rebel.
I want to match the calipers and hooks.
yellow?
I agree i saw a lot of red and yellow. On a sports car it def looks the part.red and yellow usually always flow pretty nice
the question is would it look nice on a big truck?
maybe green?
Very good question.
I also have a Flame red Rebel. I'm thinking of doing red on my calipers, and blacking out my rims.
