J92JRamsport
- Mar 5, 2020
Late contribution, but here is my AFE.  Had it on since spring of last year.  Easy install.  I think I saw maybe 1mpg better on a good day.
	For those looking to just remove the secondary carbon filter - I found it was easy to just use a small drill to drill out the plastic rivets. They are fairly soft. The frame is pretty fragile so just forcing it out will probably crack it. Drilling the rivets out allowed the frame to pop out easily. I can now always screw it back in or glue it later if needed for emissions issues, smog testing, etc...
Others have mentioned this also - but while that filter looks pretty innocent just sitting there, on removal it's thicker than it looks and I blew some air through it - it is certainly restrictive.
I have an idea for a stock airbox mod I may try - not really on topic with aftermarket CAI so will create a new post - but those reading this post if you can give me input on that thread that would be great.
Though we share the same filter box, my ecodiesel does not have that carbon filter. And I was SO prepared to remove itI just did the same. I was skeptical at first about removing the carbon filter, but what the heck (I already had the K&N drop-in filter in it). I used the drill method too but initially used too small of a drill bit and went though the box causing a tiny hole in the air box cover. Patched it up with some JB Weld KwikWeld (no biggie). The 1/4" drill bit seems to solved that problem. Just go slow and when enough of the plastic rivet is drilled through, the filter frame will pop off (probably helps to have a pilot hole drilled in the center first). I tested the carbon filter by blowing a hair dryer through it and what a surprise. I didn't realize how restrictive it was...I barely felt the air coming through.
Soon as I started her up, the sound was definitely noticeably louder than stock (not anything WOW louder but definitely noticeable). I drove it around the neighborhood and though it's not anything big, it's definitely a noticeable improvement in sound and response. I've had aftermarket CAI systems in my other vehicles and this is very comparable but without the extra cost and installation...now I don't need to spend $300 or more for an aftermarket CAI. I'm very satisfied this this setup for now.
319$?! From where?I picked mine up for $319
It's all in your head.....removing the carbon filter will have no impact on performance that you can "feel".I just did the same. I was skeptical at first about removing the carbon filter, but what the heck (I already had the K&N drop-in filter in it). I used the drill method too but initially used too small of a drill bit and went though the box causing a tiny hole in the air box cover. Patched it up with some JB Weld KwikWeld (no biggie). The 1/4" drill bit seems to solved that problem. Just go slow and when enough of the plastic rivet is drilled through, the filter frame will pop off (probably helps to have a pilot hole drilled in the center first). I tested the carbon filter by blowing a hair dryer through it and what a surprise. I didn't realize how restrictive it was...I barely felt the air coming through.
ALL performance mods if ANY kind can be completely validated by use of the butt dyno. If the butt tells you it’s performing better, that’s all we need to know.It's all in your head.....removing the carbon filter will have no impact on performance that you can "feel".
 Didn't do it for the performance factor as I knew there'd be none. When we do things like this, we'd like to believe they are making a difference, and even try to convince ourselves that they are, even though normal logic would say they are not.
 Didn't do it for the performance factor as I knew there'd be none. When we do things like this, we'd like to believe they are making a difference, and even try to convince ourselves that they are, even though normal logic would say they are not.Here’s my input. I took out the carbon filter and put a K&n drop in on then took a round trip to Graysville Tn from Johnson City. Cruise was set at 70 and here is my evic mpg. My actual was .2 mpg less.
I was averaging 19.5-20 before air box mods. That is with a borla muffler swap.
 The Vararam would be a close second.  But I don't like how they handled the breather.  It should be part of the intake not just have a little filter slapped on it.
