More front lift
Chaser1080
Looking for ways, if any, to lift my front another 1-2” to get it level with the back or just slight nose high. I have a 6” bds non-coilover kit with the bds UCAs and Fox shocks but I hate that it sits with forward rake on it like it was factory. Also, a little more clearance for my 37s would be nice. I’ve thought about the motofab spacer but it would be putting spacer on top of the bds spacer which I heard is a no-no.
What are your thoughts?
Try swapping the factory struts for bilstein 5100’s and adjusting the height to level it out!
Y
Yep I’d say go this route I did it with my gmc with 4” lift. You could also get the part #’s for the fox struts that come with the Mopar 2” kit and use those instead of the factory ones rather than buying the whole kit
can you post some pics ?
Purchase off-road package springs for the front. They will give you an extra inch.
So this is what y’all are talking about right? Just so I’m understanding this right, I’m still running stock shocks because the lift is a spacer lift and I can put this at like a 1.5” setting to lift it just a little more?
Yessir! That’s what you need to lift the front an extra inch or two.
