How to run a cable/wire from bed to inside cab?
wayn0r
Hi all,
I just bought a weboost (Drive 4G-X OTR) and installed the antenna on the bed rack. Now I need to run a COAX cable from the bed of the truck to inside the cabin.
A few questions:
1) Are there any openings that lead from inside the bed to underneath the bed which I can use to run the COAX cable through (without going all the way to the rear lights opening)?
2) If 1) is not possible I'm thinking running the cable down in the space between the cab and the bed. What would you use to make sure the cable doesn't bounce around and damage the paint over time?
3) Would you run the cable all the way to the engine bay and get it in through the firewall? Or is there a way I can get the cable into the cab through one of the storage boxes on the floor of the back row of the truck? Do you see any issues with maybe drilling a hole into the bottom of the storage box and getting the cable in that way?
Thank you,
Peter
Did you figure out anything? I need to run a cable as well for a GMRS antenna. I looked at the storage box but the wire would restrict the closing of the lid. It appears to be a wire harness under the drivers seat and a box directly under next to the frame? I haven't taken it apart to see if that box has cab access or not.
I'm not in front of my truck but there is a rubber grommet in the engine compartment below the brake booster(or nearby) from what I recall and the rubber grommet has a wire pass through hole that is sealed but it punches very easily with a hanger or something similar and will allow you to pass wire straight through to cabin.
  • Like
Reactions: WPG
I’m also looking to run a GMRS antenna. Following!
If you get under the truck and look on the rear driver's side, about where the rear seat is, you'll see a plastic cap/grommet. It's not removable, but you can easily drill a hole through it to get a wire in there. That's how I ran the wire for my cargo lights. Obviously, you'll want to pull up the carpet before you drill through the grommet.
Hi all,
A few questions:
Thank you,
Peter
Hey Peter,
I just rec'd my 4G-X OTR and also have a Diamond Back cover.. Can you please share how you mounted the outside antenna? I was hoping to install on the bed, but the mount doesn't allow enough clearance for the Diamondback to close properly. Would love to see how you went about the mounting.
Thanks in advance!
Been a year, and not a word. Got a weBoost last night. Mounted it using a FireStik pickup truck stake hole antenna mount. Also looking for a way to run the coax through the back of the cab. Thinking of drilling a hole behind the back seat, grab a rubber grommet and some silicone to seal it up.
Not a word? See post #5 for the best answer.
Here is the install for bed lights. I have not done an install but you may be able to follow and make some adaptions to the process.
I got my GMRS installed, I have a few more items to add and will post the pics when I am done with all cable runs in the next day or so.
Behind the driver-side backseat, plug-hole pics show under the cab and under the carpet, then run along the seal plate to the slot under the radio. A small slit is already in the cubby hole, I opened that hole up to get the wiring to the GMRS and scanner.
Do you have a photo of the grommet?
I ran multiple things into the cab: 2x 8 gauge power and ground cables, 1 coax for HAM radio, 2 extra 14awg cables for triggers.
I ran everything following the frame and come up via the space right by the steering shaft, then go into the cab via the rubber grommet by brake booster. You will want to cut an X to the left (front passenger side) of that big grommet, the stick a screw driver through. Be sure not to turn or twist the screw driver when you poke so you don't damage existing wiring. Then, take a fishing line or a string or something and tie it to the long screw driver, pull it out.
Detach the screw driver from the line or strong of choice, then attach it to your coax cable. pull back from inside the footwell. If it's rough, pull it back to the engine bay and apply some WD-40 as lubricant (i haven't tried other lubricant, so if you don't have WD-40 but happen to have some in the bedroom... do so at your own risk). Pull it through and attach your device, then hide the wires. apply some silicon to waterproof the whole you made and you're done.
simple as that.
I had to buy a new cell booster antenna and decided to upgrade from the small magnetic one to a larger one that looks like a whip. I passed the wire through the cab vent in the back wall.
