Just installed mine. I ended up frame mounting on the drivers side just forward of the gas tankAmazon
Did you take it out of the bed? With the spray in bed liner I couldn’t get a good ground for the ground wireYea I did driver side too after looking everything over and noticing the battery was on the driver side. It’s a simple install and I love the convenience of it.
Nm. They're on the top. My badI believe the ones near the light port are for the bed handles
Riv nutsWhat do you put in those octagon shaped hole to screw into. I have some tie down rail from another truck I want to put in without drilling new holes.
