Extended lugs?
Huskymush
Anyone here run extended lugs? Got a new wheel setup and didnt end up as aggressive as I though they would. Looking to run a 1/4"-1/2" spacer and wondering if anyone has done extended lugs since the normal adapters with the pre installed lugs wont fit without cutting the stock lug bolts.
You can run 1/4” without doing extended lugs but not 1/2”
Motorsport Tech says you can do 3/8” but I’m not sure how many threads you would have left if you did
