Bestcoast
- Dec 14, 2019
Thought I might post this here because I hadn’t seen much about doing this or the Firestone kit. I use my truck and after putting a 2” level on the front wanted to avoid excessive rear end sag when towing or loading the bed heavy.
I thought about 1.5” rear lift coils but I didn’t want to end up with factory style rake again. I started down the rabbit hole of rear airbags. I came across the firestone 2595 airbag coil replacement kit. It’s relatively basic, you get the two airbags with mounts, some air hose, Schaefer valves and a mount. I found it for around $400 and for that price I was sold especially when compared to other kits (kelderman) etc. The type of airbag firestone uses is also different than the other kits and appears to have more travel.
This isn’t my first time messing with suspension or lift kits so I felt pretty confident I could get this installed easily. It took about 4 hours taking my time. The instructions from firestone weren’t great but if you’ve installed rear coils it’s the same process to drop the rear axle down far enough to get the coils out.The airbags are held in place by a plate that clamps the upper coil bucket and a small bolt that threads into the lower mount from underneath the coil perch on the axle.
After taking some measurements I set both bags to about 40psi. All in all I’m impressed with the kit and I’ve already started looking into doing on board air so I can adjust the pressure on the fly for different loads. The ride is also better than stock so that’s also a plus.
The first pic is what happens when you put a yard of crushed granite in the back of your truck and the others are during the install. I’ll get some more of the final product later.
