Installed OEM front splash/ mud guards that match the rear dually ones. Helps protect against the rock chips and keeps the running boards much cleaner than before. Didn’t use the plastic rivers that came with them- I used bolts to better secure.
Gave mine a good wash and wax and she shines pretty good!!
Well not MINE, but I had to perform an inspection on a "Freedom Edition" .. LOL ..
Looked d@mn good though for an older truck!
(attached)
Received my Heininger Hitchmate cargo bar today. I don’t remember whose bar I had on my previous truck but there is no comparison. This thing is stout!
And I tripped over it when putting LED’s in the third brake light today and face planted in the bed of the truck. But, the cargo bar DID NOT MOVE!. And it entertained the neighbors. NO way to recover and look cool from that one.
Changed out my all satin Bold City Design rear emblem for a matte/gloss and lowered the rear
That emblem really looks nice!
Ordered while the sh*t was hitting the fan..Hydro-Blue Laramie Group 2, Air-suspension, Off-road, Sport, Uconnect 12, power running boards, dual panel moonroof.
Debadged the tailgate and doors. Super easy since it was so new. No heat needed. Used a trim tool with a rag to get the corners started and then just pulled slowly and it all peeled right off. Then just a quick hit with some adhesive remover for the residual followed up with some detail spray and that was it.
Put on the B & W Stow Away Hitch. Although I’m gonna wait until I hit 1,000 miles to tow my horse trailer and flatbed. I will use the 98 2500 until this truck gets broke in.
My truck is stock and I'm planning to keep it that way (with the exception of Line-X and a tonneau cover). I do want to gradually upgrade from halogen to LED bulbs. I wasn't going to fool with the interior lights but I ordered 194's for the license plate bulbs and apparently they're already LED so I decided to use those bulbs for the footwell lights. Also received my hitch and hitch pins.
Put on some BORA 2” spacers. Running about 2” lift on 5100s with my ORP Laramie with Rebel takeoffs. Don’t know if I’d ever have enough clearance to do 34s. It’s tight right now, but no rub!
What Tire are you running?
what size tire are you running on the Rebel rims? I was hoping to stuff 34.3 under my limited with no lift. 295/70/18. The next size down is 270/70/18 which is 33.2
Looks like he’s running a complete rebel pull off. So 33inch duratracs. This issue is, he stuck the tires out 2 inches which essentially means you can fit less of a big tire . If your staying on a stock rim with no spacers your tire will fit if you have air ride. I’m not sure on stock springs
