Desert Dawg
I rented one from advanced auto for free......$60 deposit....autozone has them too
@Z mann R2 ; I tried using the 1.5-inch wheel spacers as well but was told by my shop that they would have to grind the studs like you mentioned previously. I see you went with the 1.5-inch spacers anyway so did you have grind the studs? I am debating doing the same except grinding down the studs would basically prevent mounting any aftermarket wheels if I ever find one I like.
Do you know how much front lift you netted with the 5100s over the Rebel's factory Bilsteins? I am curious at what setting you went with and how the ride is?
