MilehighRam
- Oct 10, 2019
I decided on a DIY ceramic coating after reading all the reviews since I purchased my truck in October. Took about 15 hours over 3 days to complete. Ive got to say, Ive never owned a vehicle that looked so good! Most of the work was in the prep, and It sucked. When I was finished, my wife was staring into the hood and said “im dizzy looking at it, its like staring into the universe…I don’t even see any swirls”; that’s how I knew I did it right – it passed the wife test. I had to buy new microfiber cloths, a used DA polisher and all the items listed below. Probably $500 worth of materials, including the ceramic coating.
Its now 3 weeks since this was done, and decided to wash the last 2 snowstorms worth of crap off it. 2 things I noticed is the truck is VERY hydrophobic and it really was a lot easier to clean and dry (with a leaf blower and 1 MF cloth). Looks just like it did a month ago.
Here’s my process that I came up with, after hours of reading and researching. (bullet points didnt line up correctly, but you should get the idea)
- Touchup paint bumper
- Make sure surface is clean/grease free
- Give time to cure (overnight)
- Wash (out of direct sunlight)
- Remove tonneu cover
- Adams strip wash
- Foam cannon/gun
- Wash mitt
- Microfiber drying towel
- Make sure to get top and bottom of running boards
- Iron remover (iron x)
- Clay bar
- Remove grease with IPA
- Paint correction/polishing
- Apply polish to pad (3 to 4 spots) then tap around in your working area
- 1st step – Adams compound on microfiber cutting pad (most aggressive of 3 steps)
- 2nd step – Adams compound with blue pad
- 3rd step – Adams polish with white pad (final polishing, fine)
- 4 or so passes over same area in cross hatch pattern
- Wash/dry (out of direct sunlight)
- Adams strip wash
- Microfiber dry w/ leaf blower
- Double check at this point that the paint is up to my expectations; bring truck into direct sunlight to check.
- Panel Wipe (Gtechniq product)
- Removes any remaining oils; preps for ceramic coating and EXO
- Apply ceramic coating
- 1 layer of CSL
- Up to 2 layers of EXO (one right after the other)
- Curing – 2 days in garage
- Gtechniq recommends 12 hours
