Aftermarket 18" wheels, what fits?
ColoradoCub
Calirado
I know when these trucks fist came out some owners found out the hard way that most aftermarket 18" wheels will not clear the calipers on these larger brakes. It seems a while back I read where if you used enough offset Fuels and others could be used. Has anyone worked through this issue and upgraded their 18" wheels?
I really wanted 18” tires with my lift but sadly I had to go up to a 20” Fuel wheel for my lift.
Did you try any 18's, it seems that as long as you go with 0 or 1 offset the 18's fit, just not much info out there. I really don't care for the ride or look of 20's personally.
I just installed Method 18” wheels on mine. -12 offset. Everything clears fine
My 18” Blitzs winter wheels are -12 offset.
I have fuel Beast at "0" offset in the 18", they clear, not by a lot.
I looked into this at great length... I’m dead set on running 18” aftermarkets @ the stock +18mm offset (with 35’s) the only wheel I could find that would work was the Method NV (according to customer support @ Method).
You get a few more options if you go 0 offset, and even more when you get into negative offsets.
I ended up mounting my 35’s on my stock rims for now, I like the NV’s but see too many these days and really don’t want all black wheels on my billet silver (w/ chrome bumpers & grill) truck.
I’m hoping that someone puts out some more options in the near future.
I’ll also add that when getting that close in tolerances, you really need to verify with manufactures that a certain wheel will fit.
I had a set of Method grids (titanium +18) in my cart ready to buy from Customer Offsets. According to their site they fit my truck, I called them to see how long to ship and verify fitment - they said yes they’ll fit, but 2 weeks to ship. I decided to wait and check my local shops to see if I could get them faster than 2 weeks. My local shop said they would not fit, I called Method and verified that they would not fit.
Saved myself the time and hassle of having to return a set of wheels (that I possibly might of ended up mounting tires on not knowing better) to Custom Offsets.
Yes since lifting I couldn’t use my oem 18” wheels hence why I’m on my current set. My winter set will be a 18” wheel but with a -12 offset and sadly they will be black.
ProComp Series 46 Prodigy 18x9 Øffset
OEM Duratrac > MOPAR flaps/boards
img_20191204_103927804_cb10898c7dd10dd33e93474d4ce6426e18e67af3.jpgimg_20200112_140516155_hdr_1e8a026939def3850a543442ee879a4cd51c6587.jpg
[/QUOTE
hey Clyde. Any issues with upper control arm clearance with stock 18s and 35s?
Replacing the black 22s" that came with my limited with 18x9 -12 Fuels here soon. Here is hoping I don't have any issues with the brake caliper!
