Joshua1216
 - Mar 18, 2020
Hey all, So I installed an OEM trailer brake controller in my 2019 Ram 1500, ended up using an OBDII MX with the FCA security bypass module and AlfaOBD to flash it in myself. Enabled the ITBM and switched the three trailer options to yes like I've read on here. So the options on the 8.4 Uconnect screen come up just fine letting me make the type, name selections etc...but nothing showing up in instrument cluster even when I connected my RV to the truck. Any ideas on that? Does it make a difference enabling the ITBM if ignition is at ACC or Run? Basically when I hit + or - on the controller or push the gain lever nothing is happening. Shouldn't I be able to cycle through the Cluster until it shows Trailer Tow and see gain adjustments when my RV is connected? Any ideas on this appreciated.
