Ok so let’s just say I haven’t messed with car audio since you had to buy a separate device to have XM radio and install the antenna!
Now that we have established my age, what I’m trying to figure out is that I have changed the 6 factory speakers to try to improve the sound but not much has changed. I was considering getting a 6 channel amp and running everything into it but the 3.5s are 50 RMS while the doors are 90 RMS. I’d love to add a single sub also just to give a little bass.
Can I run just the door speakers to an amp and bridge the other two for a sub, while leaving the dash on the radio output? If not will I blow the dash if I go 6 channel amp that is 100 RMS and do a separate mono amp for the sub?
I’ll take any suggestions on equipment also.
