Pics of 295/60/r20
Steelchamps
Just pulled trigger w billsteins. Keeping stock Laramie rims. Anyone have pics?
The only thing I've seen is the RC YouTube video. Thanks.
Hop on custom offsets - they have a ton of pics of this setup..
Actually they really don't.
I've scoured this site and most have 285/60/r20.
Here's 5 that i found on a quick search. 295/60/20 - 20x9. The blue one looks perfect!
I'm running 295/60r20 on my Limited w/ORG and QL w/aftermarket wheels. Posted a thread of them a while back - if you search "295" you should find that and some other similar threads filled w/pics.
I'm running 295 60 20 on stock Laramie wheels and bilsteins
Any full pics of your setup? I have the same wheels and am looking to do a similar setup for tires/suspension
Are you having any abs/ traction control engagement issues on sweeping turns?????
This is the size I have settled on if I decide to stick with factory wheels. Gives just a touch of extra width and extra height. Right now my truck SWALLOWS the stock 32s.
I have 295/60/20’s but opted for an aftermarket wheel..... I went with a zero offset so they would stick outward a bit more. Zero issues with more than enough room.... although I do have daystar spacer and links so maybe not a good comparison. Really happy with the stance and rims at zero offset.
did you put links in the back also, or just the spacers and links in the front?
Just up front.... all stock in the rear.
I've got about a 1/4" of rake w/o the rear links. I bought all 4 but ended up adjusting the rear back to stock length. I only got about 1 3/4" of lift in the front, could get another 1/4" but then OR1 doesn't function either. Might go back up though!
Is that just links or did you do the Daystar spacers too?
Do you remember how long you made them? I did mine at 65mm
