Tailpipes dont match. One sticking out...
Hrspwr88
Hey guys,
Any having issues with their tailpipes not matching in terms of orientation?
Mine were totally misaligned from the factory, which I was able to correct. But my passenger tip sticks out way more than the drivers side. To the point that the passenger pipe is protruding from the bumper and the drivers side is recessed. I haven't found a way to fix this. Is it just me?
PorBoy
Millville NJ
Can you shout some photos so that we can advise you from there ?
Hrspwr88
Here are some pics.
WhiteLaramie2020
Louisiana
your driver side appears to be to short. passenger looks to be about right. either way I'd have them look at it.
Kidder
DFW, TX
Crawl under the truck and adjust one of them. They are just tips.
Patsy1099
People’s Republic of New Jersey
^^^this. They are tips held on by 13mm bolts. Loosen the bolts on the clamps which are just underneath and you can raise the tips higher/lower and bring them out or have them tucked in...total personal preference. Just don’t raise the tips too high, leave two fingers of space between the tip and bumper because of heat and rattle.
Hrspwr88
Hey guys, already tried adjusting. I was able to fix the left/right and up/down easy enough. But you cant pull in out out.
moparleo51
you should be able to move it out some when loosened. just take a rubber mallet or similar and persade it out some. might have to try and twist it at the same time.
moparleo51
you can also use a propane torch and heat the area on the tip section and it might loosen it up for you.
Diamondback
Midwest
That is an issue. Mine aren't IN-&-OUT but UP-&-DOWN .. We've seen a lot like mine at work.
Damion
My drivers side sticks out a bit more than the pass side. I also aligned them closer to the bumper.
I loosened the clamp and pushed it in, holding pressure while tightening the clamp, its not 100% but its much better than it was
Hrspwr88
Not sure I follow how anyone has adjusted in and out. The clamp will pull the pipe back in as it's a ball flange. You may be able to do tiny adjustments, I need an inch... lol
Patsy1099
If you pull on the pipe the rubber hangar might give you a little rotation. Maybe just enough. Not sure because when I changed my exhaust I put on different hangars. I forget how much slack the oem ones have.
