Is it possible to run a small air compressor from the 400 watt 125 volt outlet? Something like the compressor below, it's only 3 amps.
ca-jbtools.glopalstore.com
shop.slime.com
After looking at that Viair some more I have one more like this. It goes up to 150 PSI, but mine has both a 12V plug and 120V plug. https://www.amazon.com/dp/B07RXZKMX3/Thanks all for the suggestions. The Viair looks like a nice unit. I agree that the pancake compressor is overkill, but at least it can serve double duty. Any they're only $40.
That’s a scary placeI've used this one from Horror Freight and it works just fine with the rear seat outlet.
I'd like to move it to the bed. However I am trying to get an air suspension compressor from a new RAM. bolt that up in the factory place then run air lines with quick connects to the four wheel wells.
